salut Pierre,
parmi tous les gens que tu as rencontrés, as tu jamais parlé à un scientifique qui proposerait de prouver
la véracité de ta technique chinoise par caresse / grattage de la paroi anus/vagin ?
vas-tu laisser ton nom dans l'histoire de la sexologie mondiale comme le propagateur d'une technique permettant aux femmes d’éprouver des orgasmes de bien meilleure qualité ?
accepterais-tu de te soumettre à une telle expérience avec casque d'électro encéphalogramme sur la tête de ta femme et avec toi (sans casque) pour comparer la trace électrique de l'orgasme par simple cuni "normal" et la trace électrique de "l'orgasme made in Pierre Woodman" c'est à dire : un orgasme causé par la caresse buccale du cuni ET EN PLUS la caresse digitale de la paroi anus/vagin selon ta technique chinoise ?
"et le prix nobel du meilleur amant est attribué à...."
Aprés recherche sur le net les EEG semblent ne pas changer pendant l'orgasme :
cf. EEG during masturbation and ejaculation
B Graber, J W Rohrbaugh, D B Newlin, J L Varner, R J Ellingson
The occurrence of a distinctive EEG pattern specifically related to sexual arousal and orgasm would provide a reliable and convenient means of identifying such events in the laboratory and would also provide clues to cerebral structures involved in the processes. EEG-polygraph recordings were obtained under rigorously controlled conditions in four normal male subjects during masturbation and ejaculation. The EEG data were subjected to both impressionistic and quantitative analyses. They showed no remarkable changes during the sequence of relevant physiological responses. The sole effect was a slight depression of alpha activity, a well-known nonspecific effect associated with changes in attention and arousal. Examination of the literature shows little agreement among reported results of studies of EEG changes during orgasm. It is likely that at least some reported changes were artifactual. It is concluded that the case for the existence of EEG changes specifically related to sexual arousal and orgasm remains unproven.
voir EEG pendant la masturbation et l'éjaculation
B Graber, JW Rohrbaugh, DB Newlin, JL Varner, RJ Ellingson
L'apparition d'un schéma EEG distinct spécifiquement lié à l'excitation sexuelle et à l'orgasme fournirait un moyen fiable et pratique d'identifier de tels événements en laboratoire et fournirait également des indices sur les structures cérébrales impliquées dans les processus. Des enregistrements EEG-polygraphe ont été obtenus dans des conditions rigoureusement contrôlées chez quatre sujets masculins normaux pendant la masturbation et l'éjaculation. Les données EEG ont été soumises à des analyses impressionnistes et quantitatives. Ils n'ont montré aucun changement remarquable au cours de la séquence de réponses physiologiques pertinentes. Le seul effet était une légère dépression de l'activité alpha, un effet non spécifique bien connu associé à des changements d'attention et d'éveil. L'examen de la littérature montre peu de concordance entre les résultats rapportés des études sur les modifications de l'EEG pendant l'orgasme. Il est probable qu'au moins certains des changements signalés étaient des artefacts. Il est conclu que le cas de l'existence de changements EEG spécifiquement liés à l'excitation sexuelle et à l'orgasme reste à prouver.
General discussion about women orgasm
saleousucre
Re: intensité de l'orgasme et électro-encéphalogramme
C'est un excellent sujet de discussion !!!
Trés franchement je m'en tape de ce que disent les scientifiques parce que moi j'ai les milliers de filles pour prouver et dire que dans plus de 90 % des cas mon "systeme" cuni-anal apporte des orgasmes bien plus fort qu'un simple cuni ou masturbation.
On voit dans mes videos que souvent je termine avec un simple cunilingus qui peut s'averer très violent aussi mais est toujours différent en terme de sensations que celui ( ceux ) de ma préparation anale.
De plus le cuni + vaginal n'apporte presque jamais un résultat similaire pour la simple raison que la tension de la peau autour du vagin garde une couverture sur le clitoris et ne permet pas une stimulation aussi "aérienne" que lorsqu'un pénis est dans l'anus !!!
saleousucre
salut Pierre,
merci de ta réponse. Comme par son secret chinois tu doubles la stimulation nerveuse en caressant le nerf du clito et en caressant le nerf qui est entre le vagin et l'anus, il est normal que le résultat soit double.
je suis surpris que cela ne donne rien sur l'électro encéphalogramme, mais il doit bien y avoir dans le cerveau
des marqueurs, des trucs qui changent selon l'intensité du plaisir puisque parfois l'orgasme est fantastique et parfois il est juste bien.
Le chanteur Sting, qui s'est fait l'apôtre du sexe tantra a dit qu'il prenait mille fois plus son pieds à 50 ans qu'à 25 ans.
N'empêche, je pense que par l'IRM ou une autre invention, on arrivera un jour à mesurer l'intensité de l'orgasme de l'homme comme celui de la femme.
Jean
Si je peux apporter une précision, dans bon nombres d'interview, il formule sa pratique "secrète" ainsi : "j'attrape un nerf qui passe entre l'anus et le vagin et je crée une connexion qui produit un plaisir intense !", Donc, il s'agit bien d'attraper/saisir, d'une certaine façon, et non pas "caresser", c'est à Pierre de confirmer si ce que je dis est juste, ou non
saleousucre
salut Jean,
oui, je crois qu'il a dit dans une vidéo qu'il faisait le geste de gratter vers l'intérieur
comme si tu disais "viens par ici toi", ce geste là avec le doigt
mais je crois qu'il a aussi dit qu'il a essayé d'apprendre le truc à plusieurs gars et
que personne n'y arrive. Il y a une ramification du nerf sexuel entre la paroi du vagin et de l'anus, je ne sais pas s'il est plus côté vagin ou plus côté anus
je crois aussi qu'il met un gant ou un preservatif sur le doigt qui rentre, car il en avait marre que son doigt sente les matières fécales....
je ne sais pas si Pierre a déjà parlé de son truc avec des chinois de chine ou de taiwan
saleousucre
Jean,
ton idée est que Pierre saisit le nerf comme on pincerait un spaghetti ?
Jean
Dans ce sens, oui, mais je pense qu'il doit y avoir une précision limite "chirurgicale" dans le doigté, les mouvements, rythme, pression, ect, n'oublions pas aussi qu'on parle de Pierre Woodman, le gars au milliers de femmes, j'imagine qu'il a affiné sa pratique par rapport à ses débuts, ectsaleousucre wrote: ↑Sat Oct 29, 2022 1:43 amJean,
ahahahah vous me mettez dans l'embarras les amis !!!
Effectivement j'ai développé ma pratique avec le nombre de partenaires mais honnetement la stimulation anale je la pratique quasiment de la même manière qu'à mes débuts à14/15 ans mais par contre j'ai appris les multi variantes du clitoris au fil du temps !!!
Ultra
Re: EEG changes to orgasm remains unproven
My thought on reading details of studies like that on men is that 'all orgasms aren't the same'. For myself at least, if I went into a lab and masturbated till I had an 'orgasm' into a cup like at a sperm bank, the feeling and I'm sure EEG response would not be remotely on the same level as I get after real sex or at the end of enjoying a decent porn scene. I'd be very surprised if a similar type of distinction wouldn't also exist for women"!saleousucre wrote: ↑Sun Oct 23, 2022 12:03 amAprés recherche sur le net les EEG semblent ne pas changer pendant l'orgasme :
Ultimately though I don't really see the value in EEG assessments in this type of situation. All they could potentially show would be differences but there would be no way of assessing the significance of any differences beyond asking the participants how they felt. At which point you may as well just do the latter and forget about any fancy machinery.
There are IMO a lot of different type of orgasm for men and women but women are advantaged with much more possibilities.
